06RKguy
Greetings to everyone! I'm new to solar, but I am a retired electrician with some solar training. I have never had any hands on experience. I plan on installing a modest solar setup on my cargo trailer camper. It has a 30 amp RV input that I use with shore power, and a generator, but I want to power all the 12v stuff with solar when dispersed camping, and not using my generator. I have a "Battery Tender" LiFePO4 lithium charger that I plan to use to keep the battery charged and maintained when not in use, but it is a trickle charger so I will be upgrading it to something that charges a little faster. I use the Battery Tender when either plugged into shore power, or when on my generator. I do not plan on using the charger when on solar. I have a LiFePO4 100 ah battery and want to provide 12 volts for a 12 volt refrigerator, lights, a 12 volt tv, Maxx vent fan and for charging my cell phone. I also have a laptop and tv antenna signal booster that will be plugged into the inverter. Not all of these things will be running at the same time. I am planning on starting out with a couple of 100 watt solar panels for 200 watts total, and a 1000 watt pure sine inverter for the minimal 120 volt loads. Does this sound like a reasonable setup? Thank you for any input and suggestions...
