Hi,
I built my pack using new EVE 280Ah matched cells, didn't top balance at first but used the bulk charging of my mpp-solar inverter, saw that cell #13 was always the lowest, and couldn't charge over 3.4v.
Here are some JK-BMS app screens before top balancing :
A 0% lowest is #13 =============== Next day at 100% ============ During normal use cells seems balanced
So I disassembled the pack and then top balanced them in parallel, rested overnight, and plugged it back in my inverter.
The cell #13 is always the lowest voltage as shown.
Between the 1st build and 2nd build after top balancing, the busbars have been shuffled, and nuts have been tightened again, and still #13 the issue, can anyone tell me the issue ?
Could this be a terminal oxydation on this particular cell ?
Yesterday when charging using solar, the #13 was the highest voltage but still the lowest on load.
If someone has any clue, cells are a month old ?
Regards,
Regards,
