SniperX
- Apr 1, 2021
- 437
If you were Off-grid, the panels were mounted on the ground, and money was not a factor, which would you purchase? I haven't seen much in the way of Solark 15k tested against a Schneider 6848 but I have seen the Solark 12k against the 6848. Is the different-sized MPPT pv inputs on the 18kpv limiting with the larger panels in the 450W range? I am at a crossroads here...They already are. The Solark 15k and EG418k both do everything that you would want a unit to do and are easy to install, not too bad to configure and price efficient. The only thing the 6848 has going for it is the absolutely incredible capacity overhead it has. Basically I see it as a power inverter and nothing more.
And I just saw the announcement at luxpower have integrated with tigo monitoring, this is becoming a One-Stop shop plug and play.
