a pwm for two 100 watts and a mppt for the 2 300 watts I have coming
The only other thing is some people have occasionally suggested that a PWM with a MPPT on the same bank make their mppt behave funny.
I think for most people this is not a problem but something to be aware of.
On the other hand I saw that the little Epever mppt was like $50 on amazone recently. The two 100W panels in series on that could be a nice bonus.
If it were me I might offload the 100W panels and get one more 200W for 2S2P
Or if the specs are close, the two 100W panels in series with one 200W panel in one string and two 200W panels in series for a second string could be a possibility.
I have running 600W of 100W panels running on a 50A mppt right now. A couple late gizmo parts- and the snowy weather- are the only reason I’m not running 800W right now. A part or two and a couple hours and I could plug them in.
I have two arrays facing 90 degrees apart so that I spread my input over the day. Whatever I ‘lose’ isn’t really lost: I gain daily exposure time.
What you need to focus on is the output voltage of each string of panels. What is the Vmp of these new 300W panels. If they are ~36-37Vmp, then you might be able to make it work. If you wire your two Renogy 100W panels in series it will be around 18Vmp + 18Vmp = 36Vmp. That would be one 36V string putting out about 5A. Each 300W panel would be putting out ~36-37Vmp at ~8A. So, if the two 100W panels are in series, along with the two 300W panels in parallel, you'd have three parallel 36V strings putting out 5A + 8A + 8A = 21A at ~36Vmp. As long as each string is 36V, they will be compatible with each other, as long as each voltage string does not vary by more than 5%. This will work best on a 12V system, though likely to be OK on a 24V system, using the MPPT controller you have. I'd give away or sell the PWM controller.Thanks Ihave 2 100 watt Renogy’s I’m not sure what brand the 2 300 watts can I put them on the same charge controller or should I use 2 charge controllers the charge controller I have a pwm for two 100 watts and a mppt for the 2 300 watts I have coming
There is not any info on the panels but according to specs online they are notWhat you need to focus on is the output voltage of each string of panels. What is the Vmp of these new 300W panels. If they are ~36-37Vmp, then you might be able to make it work. If you wire your two Renogy 100W panels in series it will be around 18Vmp + 18Vmp = 36Vmp. That would be one 36V string putting out about 5A. Each 300W panel would be putting out ~36-37Vmp at ~8A. So, if the two 100W panels are in series, along with the two 300W panels in parallel, you'd have three parallel 36V strings putting out 5A + 8A + 8A = 21A at ~36Vmp. As long as each string is 36V, they will be compatible with each other, as long as each voltage string does not vary by more than 5%. This will work best on a 12V system, though likely to be OK on a 24V system, using the MPPT controller you have. I'd give away or sell the PWM controller.
according specs the 300watt panels coming in will be 18VmpWhat you need to focus on is the output voltage of each string of panels. What is the Vmp of these new 300W panels. If they are ~36-37Vmp, then you might be able to make it work. If you wire your two Renogy 100W panels in series it will be around 18Vmp + 18Vmp = 36Vmp. That would be one 36V string putting out about 5A. Each 300W panel would be putting out ~36-37Vmp at ~8A. So, if the two 100W panels are in series, along with the two 300W panels in parallel, you'd have three parallel 36V strings putting out 5A + 8A + 8A = 21A at ~36Vmp. As long as each string is 36V, they will be compatible with each other, as long as each voltage string does not vary by more than 5%. This will work best on a 12V system, though likely to be OK on a 24V system, using the MPPT controller you have. I'd give away or sell the PWM controller.
This seems very unlikely? I've never heard of a 300W 12V panel before? Are you sure it's not a "300W kit" containing three 100W panels? Can you please provide a link to the specs you are referring to?according specs the 300watt panels coming in will be 18Vmp
I don’t know how to send a link but here pictures of the specsThis seems very unlikely? I've never heard of a 300W 12V panel before? Are you sure it's not a "300W kit" containing three 100W panels? Can you please provide a link to the specs you are referring to?
In any case, matching string voltages WILL work, as long as voltages match up by less than 5% deviation.
Plus: if you return that you will more than likely be able to purchase rigid, longer lasting, and compatible panels for much less money. An mppt will charge well if you give it good input.looks like 300W is for two panels combined since it shows two panels in the kit, so more likely to be 150W panel.
THat’s not supposed to happen. ?Not in my case.
All controllers run the same charge parameters. The PWM tends to do most of the work and the MPPT's pick up the slack if needed.
