Chargery BMS News / UPDATE (Nov.25.2020) Ver 4.02 firmware
Conundrum....
Powering down a RV for winter storage, ideally whereby the negative terminal on the house battery is disconnected, but the BMS is still connected/powered via the sense cables, could the BMS take a 280AH pack down below LVD over a six month period, more so if the pack was put to storage at 50% capacity? I feel this leaves my pack potentially unprotected.
On the other hand, if you power the BMS through the external input, this generally means using an AC/DC adapter, connected to the inverter, which means that it must be left permanently powered up, which in itself draws the battery down at an even higher rate. At least this way, the LVD will protect the pack.
If i completely switch off the BMS, then i assume i need to reset all the configuration settings when powered back up at a later date? I cant get the latest software updates(i'm on version 4.0 at present)
Anyone know what the parasitic drain of a BMS8T is, when sitting there measuring the voltages?
Could the diagram below work, such that i still have LVD control but not need to run inverter? I know there might be a potential issue with grounds, but dont know if this has been resolved?
If the Chargery BMS is in storage mode .... Just press the stop button. This will de-energize the charge and load output and turn off the BMS..... I don't know what the passive draw would be in that mode, but it is very low.
Maybe @Chargery will check in an let us know what the BMS power usage is in that mode.
Yes im aware of that function, but if connected through the sense wires, even at a very low draw in storage mode, you are still in reality unprotected in a low voltage situation? Take for example a situation where you think you are putting pack into storage at 50% capacity, but in reality it has been miss reported and in fact you are only at say 15% capacity...how long before you potentially run into trouble?
Like you say, we just need to know how minimal the draw is (plus you need to remember to press the stop button when shutting down...lol)
on BMS manual there is a table that include the current drain from battery at different mode and battery voltage,
the follwing fist tabale is for BMS8T, take a 4S LiFe battery as a sample, the cell voltage at storage mode is 3.3V, total battery voltage is 13.2V, at sleep mode, the current from battery is around 28mA, if storage 6 months, the BMS will consume 120.96AH, if plus battery self discharge, the data will be more.
if turn off BMS, BMS still consume current from battery by sense voltage wire, but the current is very small, it is aroun 0.12mA(for 4S LiFe battery and cell average voltage is 3.3V), 0.45mA(for 4S LiFe battery and cell average voltage is 3.3V). at this mode, the consumption power (0.45mA drain) is under 2AH for 6 months storage.
if update BMS to V4.03 (main unit) and V4.02(LCD unit), when turn on BMS again, all setting parameters will be resumed as same before turn off, but the SOC , AH and WH reading is wrong due to battery capacity going down during storage.
obviously, 6 months is too long, in fact, for all lithium ion battery, it must be charged to 100% and then discharged to 0% every 3 months, and charge to storage voltage to continue to storage. on any lithium ion battery datasheet, the storage conditions including temperature and SOC should be found.
BMS8T:
BMS16T:
BMS24T:
"if update BMS to V4.03 (main unit) and V4.02(LCD unit), when turn on BMS again, all setting parameters will be resumed as same before turn off, but the SOC , AH and WH reading is wrong due to battery capacity going down during storage.
obviously, 6 months is too long, in fact, for all lithium ion battery, it must be charged to 100% and then discharged to 0% every 3 months, and charge to storage voltage to continue to storage. on any lithium ion battery datasheet, the storage conditions including temperature and SOC should be found."
Great info Jason,
However the storage conditions for my particular cells datasheet suggests that 6 months storage is ok, and that the battery pack should be charged and discharged, but not necessarily from 100% to 0%(many folks just run their cells from 80% to 20% SOC permanently, for longevity reasons).
8.1 Long-term storage
Batteries should be stored (more than 1 month) indoor with a dry and clean environment at 0 ℃~35 ℃. Avoiding contact with corrosive substances and staying away from fire and heat source. The battery should be charged and discharged every 6 months. The voltage for storage is between 3. 0~3.3 V (30 ~ 50% SOC).
Perhaps I’m missing something but if the battery is in storage and loads are disconnected there is no benefit to keeping the BMS connected.
I would definitely disconnect the BMS for storage.
I dont want to lose all the configuration settings, since i will not be taking the pack to 100% or 0% soc thereafter. I cant get the version 4.03 update which i believe you need to maintain the settings(from a previous post)
Well I disconnected mine for storage. I can redo the settings in less than a minute.
There are YouTube videos of people who have killed their batteries in storage via BMS discharge.
Your cells,your choice though.
Yes i understand your reasoning, but surely after you redo the settings and then only charge to 80% soc, your readings will be all wrong, or do you charge once more to 100% SOC?
If i run my battery pack power to the external power source input, through a SSR connected to the discharge relay, then the LVD should protect me if the pack does go to low???
Edit...
To let you understand, i will only be setting up the RV electrics once and have no intention of tinkering later. I only intend to run my cells from around 3.1v/cell to 3.4v/cell, so might struggle to get to 100% SOC. I wont have any balancing function active. I'm determining the best method to power down the rv over winter.
My opinion is that the Chargery SOC is worthless at best, misleading at worst.
So I use a Victron SmartShunt.
For me the only way to avoid phantom loads is to disconnect. Stuff happens and the risk of ruining an expensive battery is not worth the reward of avoiding one minute of work.
Again, just my choice to protect my investment.
Yeah joe, i have a BMV712 for measuring my SOC. I'm using the chargery purely for the disconnect protections only. No SOC measurement or balancing.
Thanks for your input. (y)
I agree with the stuff happens argument .... and I also subscribe to the idea of being more careful than you think is necessary.
I also appreciate the input from Jason.
WOW: New Information for my Learning More All The Time Program. I did not previously know about that one. Are there any contrasting opinions? I will be putting this on my To Do List, .. while wondering how many folks never do that. Thank you for educational tip ( I think) :+)
I wont be doing this, preferring to run between 3.1v - 3.4v/cell usage. Above 3.43/cell and my cells diverge, so i dont wish to go there.
Not sure if Jason's suggestion is simply for re calibration of the SOC/AH output values rather than for the general health of the battery???
Conundrum....
I realise there is a big error in my sketch above ....drawn in haste. The diagram below is my corrected one. Unfortunately i couldn't edit the original incorrect diagram.External power corrected diagram..png
Do you still use the shunt attachment with the Chargery? I have been trying to figure out if that would work. I really just want the high low cell protection.
Yes since it was connected before I got the SmartShunt. There is very little resistance so no overhead to worry about but if I ever disassemble the battery I might leave it out upon reassembly.
You need the shunt for the Over Current Protection...if you dont use the chargery, you need to use another one and recalibrate the chargery to the different shunt.
Great info Jason,
yes, differenct cell manufacture has different storage requirments, because the cell self discharge rate is different. every 3 months, battery pack discharge to 0 and charge to 100% can resume battery original capacity, discharge to 20% and charge to 80% is not the best, but it workable. when charge in 100AH, battery cannot discharge out 100Ah, why? with the cycels increase, when in 100AH, only out 90AH, because the battery meterial microstruture is damaged.
so undertand battery, using battery according to battery datasheet is very important. storage for 3 months, and do a charge-discharge deeply cycel is suggested.
almost good battery or A grade battery manufatured by famous manufactures don't sell in DIY market. the good cell must have almost same volage, same resistance and same capacity before assembel battery bank , fit with good BMS to monitor each cell volage, current, cycles, and other kinds of protecion design, all parameters is preset before delivery, warranty 2000 cycles or 3 years, not only focus on each part performance but also optimize total system performance. these battery banks are used on 5G communication base station at a large volume in China.
Chargey will be ready to provide our customer in DIY market the A grade battery bank in future.
The following picture is the 48V 100AH 16S LiFePO4 battery bank.
@Chargery
Thanks for that info Jason. You are the first person i have read, saying that you must do a 100% charge or a 0% discharge to maintain capacity. I have EVE 280ah commodity cells, which are not 'matched' from manufacturer, but have been top balanced by myself. If i push the cells into the knees, then i will have divergence problems between cells and potential drift. I'm glad you at suggested that my solution of 20-80% is at least workable.
Do you have any links to charts which show the degradation of capacity, when using less than the 100% ? Everything i had seen up till now, shows that using less capacity enhances the number of cycles....so that is what i was aiming for. I was hoping for approx 5000 cycles at 50% capacity useage?
I just wish to express my thanks, that whilst running your business, you take the time out to respond to enquiries on a forum. Your units might not be perfect for every application, no single item ever is, but your responsiveness is second to none. (y)
I should point out that Jason's efforts also include him having to translate everything back & forth and make sense of it in the process. This speaks Volumes with regards to his interest in making Chargery Bigger, Better, and more capable for all of us collectively.
How many Manufacturers or even Vendors have an "Active Presence" on a forum and interact with the members while Listening AND Hearing what is being said to them ? It is RARE ! Even moreso when there is such a Language Barrier.
I realise there is a big error in my sketch above ....drawn in haste. The diagram below is my corrected one. Unfortunately i couldn't edit the original incorrect diagram.View attachment 30556
Interesting; ...and to confirm: You get slightly more accurate voltage readings on cell #1, and # 8 in battery bank? by powering the BMS via its' external power plug vs the BMS 8 wire loom? ... And Coud you once again confirm: What is the advantage or purpose of that diode (again)? I think I want to try this out on my next remove and update firmware cycle.
I'm no expert, just learning this as i go along. Jason from Chargery has posted info on this previously, which i need to defer to. My understanding is, there is a potential issue, between the ground of the BMS being different from the ground of the battery pack, so the diode prevents this problem. I might well be wrong in my interpretation.
From my own perspective, i want the sensing loom to only measure the cell voltages the most accurate way they can. Independant power to the DC input, allows me to use greater guage wire(thicker) and also a control element through the disconnect function. Even if this is triggered and it powers down the BMS, i know to look for the problem, but can simply slide the switch to the wiring loom position just to see what the display is telling me, so its not a biggie.
Ideally for me, come october, i wish to power down everything bar the BMS. This i want to put to storage mode, but still powered. The disconnect protects me from completely taking my pack to low, but i still get info if/when i decide to check on things. At only 22mA draw, i reckon things should be ok from a 280AH 24V pack, even for six months, but i would check things anyway, say the end of every month.
ps edit... i have not constructed this as yet, still accumulating all parts, so i cant say for sure on the inproved accuracy aspect, however, that is my understanding of it. My charge/discharge relays will output to SSR's of extremely low amp draw, so i wont get so much appreciable difference in accuracy. Think my total will be approx 40mA, but on a 24v system supply, it will be fairly negilable difference on the cell1 & cell 8 readings.
I have to say, i think Will's video on the Chargery unit, done it a bit of a disservice. If you are using the supplied shunt which is already calibrated to the system, then the user functions are a lot easier than Will makes out. I'm a 'not too bright' technophobe user of the system and found it to be fairly straight forward. It is fairly disconcerting when the SOC/kWh readings seem so out of whack, until you complete a capacity test (full charge to full discharge) and input the accurate figures for your own particular pack, then it all comes good and makes sense....in my humble opinion.
If however, you are an advanced user and wish to use a different shunt, then yes, i can get to be a bit of a faff, but how many users will go to the trouble of installing a new shunt?
ps edit...i'd better add, as regards Will's video, it is not a critisism, simply a personal observational opinion
