To be honest, i'm not overly concerned as i'm really only dedicating my chargery to the task of measuring voltage and providing protections. I'm not relying on it for SOC calcs or balancing function.I'd shoot him a message ....or Just tag @Chargery here and see it he can get it posted.
Folks, I said it before and it got lost in the thread. This Version 4.04 IS A BIG IMPROVEMENT !all new firmware for all BMS models are posted on https://chargery.com/update.asp
Main uint V4.04, Improve AH reading.
For all models, the latest version of LCD is V4.02, The latest version of main BMS unit is V4.04
Correct, balance start when all cell voltage over "start balance voltage" setting, under 3.2V, when battery is in charging, the cell voltage difference will drop automatically, or the cell voltage can be resumed balanced partly, for very large voltage difference battery, 3.2V of start balance voltage setting is good for balancing as fast as possible.but lately think I was educated that means balance start & then works @ > 3.4v / and none happens below 3.4v. .... Is that correct?? ... and if it is; Why not set balance to start at a lower to 3.25v, or 3.20V ?
@Chargery ..... He talked about updating but didn't actually do it in this video. Looks like he was still on the old, old 1.22please watche the update video ongood luck
The guy also does not understand the battery tech by not using Cell Level cutoff etc... This is one guy who WILL pooch his batteries. Thinks his Inverter will do the BMS' job... oivey...This video has nothing to do with updating the firmware
Chargery is redesigning the BMS. I would wait.
Hi Steve. What do you know about the P Series and would you anticipate significant risk is to the early purchasers? Presumably there is a pull through from the latest software so I guess the key risk is around new units and functionality and how much testing has been conducted. Directed to you as you appear to be quite invested in the products, apologies if you don't have the insight.....It is my understanding that the new "P" series of BMS' are to be released for February.
Unfortunately, Chinese New Year kicks in and so much for any shipments etc until at "least" Feb 21 at the earliest.
If whatever you are ordering is not on the boat / plane by Feb 01, well... you're waiting...
Thanks Steve. I'm not really in a position to wait for too long as my cells are en-route and I would like to be installed and tested by end of March! I will see what Jason says about the new device before making up my mind on whether to wait. I know you have many of the original in use - are you now content with the operation i.e. should I be reasonably content to proceed with the latest firmware. Fwiw - I have read the manual you produced and it reads well!!Well I can't really say too much more than what has already been stated by Jason with regards to the "P" series.
Active Balancing, RS232/485/CanBus comms, better UI, still uses external DCC (Relay/Contactor).
Jason has been beating on the test models, busting them and improving them and now in final stages.
A LOT of input / suggestions taken from us here and incorporated into the new version.
I have not seen any docs or anything, I dunno what Jason is decided to with the docs, I would have edited them as well but he hasn't sent me anything so I dunno. I redid some of manuals but gave up when given incomplete info which then changed without my knowledge so I could not update and then I got CRAPPED on for docs being out of whack.
Considering the new DCC Manual is such a bodged up mess of contradiction, I'm staying out of it, unless asked and provided with all the correct info.
