When the Manual was written, the DCC was still being developed with our members involved. Once the DCC was developed the manual was updated accordingly. Later the DCC was updated and the ISO Board and other components added and at that time the ability to put the DCC on the (+) side became the preferred method. Jason made updates to the docs after that, as I am not maintaining their DOCS.
My involvement with Chargery was my own initiative to redo their manuals because the previous Chinese to English (Google Translated Mess) was "Horrid" and required decoding, That process and other things like being one of the rare BMS' at the time having Hi & Lo Temp Sensing and external interface capabilities, which were not common then. The DCC Evolved from a need to use non-Electro-Mechanical Energy Guzzling relays. A couple of us started to get Solid State Relays and even commissioned custom ones and experimenting and Jason of Chargery was convinced into creating such in-house. All of the Historical Threads (Really Long) are on the forum.
PS: I tried to help people with Chargery and most were really good but after a few serious cases of belligerence and assorted accusations and general "krap" I stopped trying to help with it in general. I've always been an OpenSource Shareware kind of guy but it appears that is not acceptable to many anymore, so it is what it is.
Have Fun & Good Luck.
BTW: Here are the Chargery Settings which I used for a 5 Pack Battery Bank consisting of 3x280AH & 2x174AH.
Setting | Default | My settings | NOTES |
Over charge P Voltage | 3.65 | 3.65 | |
Over charge R Voltage | 3.55 | 3.55 | |
Over charge Current | 50 | 86A / 150A | 0.5C rate for 174AH / 280AH |
Over Discharge P Voltage | 3.00 | 2.65 | CUTOFF Trigger |
Over Discharge R Voltage | 2.00 | 2.75 | Release @ this V. |
Over Discharge Current | 300 | 175A / 250A | 1.0C Rate for 174AH / 280AH |
Low SOC cutoff | 20% | 0% | forces cutoff @ % (faulty) |
High Temp cutoff | 50C | 70C | |
Diff of Batt Temp | 10 | 15C | |
Diff of cell Voltage | 30mv | 200mv | Unmatched cells drift, |
Temp Unit | C | C | |
Key Beeper | ON | ON | |
LCD Backlight | 10 | 10min | |
Cut off Delay Time | 10 | 10S | |
Current Calibration | | -SET- | |
Temp Alarm | ON | ON | |
Cell Empty Voltage | 2.50 | 2.50 | |
Cell Full Voltage | 4.20? | 3.65 | |
Default Setting | | Enable | |
Balance Parameter | | -SET- (OFF)* | Passive is ON charge only, start at 3.40V, 30mv diff. |
Battery Capacity AH | 1 | 174 | 280 | Label Value of cells |
Battery Power WH | 1000 | 4554 | 7168 | FORMULA (NominalVolts * #ofCells * RatedAH) (3.2*8*280=7168) |
Low Temp cut off in Charge | 2C | 2C | |
Low Temp cut off in Discharge | -10 | -10C | |
