Chargery DCC
Dyotat100
Wondering what the trick is to making it work. I put it on positive side with the board and it won't let my solar through. Did the same on negative and lit let's 22 watts through.
What could be wrong?
There was a reason to put it on the positive side. I ordered the inline ISO board.
I have had the stuff for almost a year and working on finishing it.
Solar is putting out 100 amps 12v and I was going to use the DCC to turn off the solar. Only
I was just hoping someone had issues and had figured it out. Already sent email and waiting on reply
The Chargery BMS is contactor based and in no way is capable of LIMITING the charge current .... either it is charging or it is not.
So ... If you aren't getting enough charge current, you would need to be looking at other aspects of the charge circuit.
If charging was disabled by the BMS .... that would be a different issue.
I have serveral Chargery(s). One thing - you HAVE to have the temp sensors plugged in and they must 'work' (can't be damaged) for Chargery to work.
Yeah I was surprised also. I be back in a few and go through it again. Not finding any parameters in it for dcc
BMS's and the Chargery MOSFET based DCC use N-channel MOSFET's because they provide lower Rs for cost of MOSFET than a P-ch MOSFET.
This means N-ch MOSFET gate must be pulled 12-15v higher than source of turned on MOSFET, which is why they are on negative battery line.
It would be possible to put on positive line if the unit provides its own boosted supply to provide 15v above positive battery but I doubt they would do this. Then there are other control line items that need to be ground (negative line) referenced which would have to be isolated from MOSFET drivers.
A lot of extra expense.
So on negative it let's 44 watts in and 0 when unplugged. On positive with the ISO board nothing lights up and 0 watts.
Waiting for reply from chargery.
Page 4 of DCC manual states normal connection is DCC switch put in Negative battery line.
"Chargery DCC installation details.
Warning:
1. When installing Lugs, DO NOT Allow the lugs to make contact with the DCC Casing.
2. Do not allow the lugs to touch each other & short out.
3. The CHARGERY DCC should be installed on the battery negative, after the shunt. The shunt
should be between the DCC & Battery itself. If fit with our ISO board, it can be installed on
battery positive side."
There is an optional ISO board that bootstraps control lines above battery positive to give ability to put DCC switch in positive battery line. This is not the normal hookup with the Chargery blue BMS box.
To make things worse, the manual on page 8 shows a connection diagram showing the ISO board option, BUT MANUAL DOES NOT HAVE A CONNECTION DIAGRAM FOR NORMAL NON-ISO BOARD HOOKUP.
May have damaged DCC if put in positive battery line without optional ISO board.
Very poor manual, inducing a user to hook it up wrong unless they carefully read and understand it.
I got it to work with help from chargery. Turns out that you need to turn off BMS. When I turned it on the ISO board lights came on. Then turned on the DCC and lights came on.
So I put it back inline on positive side of my solar feed. I used my power supply to test it. Works great. Had it set at 3.4v off and 3.38 on. Would cycle on and off. Can't wait to see how it does with the solar tomorrow.
With a 100 amps coming in most of the day I was having to bump up the voltage to 14.7 to keep it from going into float. It would go into float below 40% charge. Fine if I'm around and able to check on it but can't leave it alone. I had the vitron setup at 14.1 and 13.60 float. Worked great on 20-30% charges with 70 amp peak. 100 amp by 9 am changed that. Tomorrow is the test.
Thanks for all the input
Congrats! Must feel good / sigh of relief that after paying $ and hooking it up its actually working! :)
Yes it does. I have been using 12v 560 ah battery with no protection. Have inverter set to turn off at 11.5 volts. Had charger fine tuned pretty good also.
Solar was pretty good but the more amps I run the harder it has been. I feel pretty good now that it turns off exactly when told to.
I order another Chargery BMS and 2 DCC. Going to build another pack.
When the Manual was written, the DCC was still being developed with our members involved. Once the DCC was developed the manual was updated accordingly. Later the DCC was updated and the ISO Board and other components added and at that time the ability to put the DCC on the (+) side became the preferred method. Jason made updates to the docs after that, as I am not maintaining their DOCS.
My involvement with Chargery was my own initiative to redo their manuals because the previous Chinese to English (Google Translated Mess) was "Horrid" and required decoding, That process and other things like being one of the rare BMS' at the time having Hi & Lo Temp Sensing and external interface capabilities, which were not common then. The DCC Evolved from a need to use non-Electro-Mechanical Energy Guzzling relays. A couple of us started to get Solid State Relays and even commissioned custom ones and experimenting and Jason of Chargery was convinced into creating such in-house. All of the Historical Threads (Really Long) are on the forum.
PS: I tried to help people with Chargery and most were really good but after a few serious cases of belligerence and assorted accusations and general "krap" I stopped trying to help with it in general. I've always been an OpenSource Shareware kind of guy but it appears that is not acceptable to many anymore, so it is what it is.
Have Fun & Good Luck.
BTW: Here are the Chargery Settings which I used for a 5 Pack Battery Bank consisting of 3x280AH & 2x174AH.
SettingDefaultMy settingsNOTES
Over charge P Voltage3.653.65
Over charge R Voltage3.553.55
Over charge Current5086A / 150A0.5C rate for 174AH / 280AH
Over Discharge P Voltage3.002.65CUTOFF Trigger
Over Discharge R Voltage2.002.75Release @ this V.
Over Discharge Current300175A / 250A1.0C Rate for 174AH / 280AH
Low SOC cutoff20%0%forces cutoff @ % (faulty)
High Temp cutoff50C70C
Diff of Batt Temp1015C
Diff of cell Voltage30mv200mvUnmatched cells drift,
Temp UnitCC
Key BeeperONON
LCD Backlight1010min
Cut off Delay Time1010S
Current Calibration-SET-
Temp AlarmONON
Cell Empty Voltage2.502.50
Cell Full Voltage4.20?3.65
Default SettingEnable
Balance Parameter-SET- (OFF)*Passive is ON charge only, start at 3.40V, 30mv diff.
Battery Capacity AH1174 | 280Label Value of cells
Battery Power WH10004554 | 7168FORMULA (NominalVolts * #ofCells * RatedAH) (3.2*8*280=7168)
Low Temp cut off in Charge2C2C
Low Temp cut off in Discharge-10-10C
Thanks
Pretty close to what I have been running. Battery has been together for about a year. I used it for a weekend in my 5th wheel camping last March. Then it sat until a couple of months ago when I picked up some solar panels. I have been experimenting with the panels using battery and my inverter.
I'm waiting for my inverters for house and will take it off the grid. SCE is out of control with rate increases.
Temp UnitCC
Key BeeperONON
Temp AlarmONON
You take your cells up to 3.65 volts? I was trying to do 80% cycle. I'm set at 3.41 volts
I never take my cells to 3.650, they are set to be at 100% at 3.425Vpc.
BMS is the Emergency Brake and is set accordingly relative to LFP Full Voltage Curve rather than the Working Voltage Curve of 3.000-3.400.
My Systemic window charges to 3.425 and does not go below 2.950 but does allow for Load Sag which can take it lower for a few moments should a heavy load surge pop up.
My SCC (Midnite Classic 200) is programmed to deliver that charge and is Voltage Corrected so that is what is actually happening at the "Battery Terminals". Also My Inverter/Charger (Samlex EVO-4024) is also voltage corrected to force cutoff at 2.635V per cell.
It is really important to know that whatever your SCC or Inverter system display is NOT Nescesarily what is seen at the Battery Terminals because with every connector, fuse, breaker, lug, there will be some loss in both Voltage & Amperage. Hence why I wrote a piece on Calibrating systems but few ever take the time to look and consider it.
