Bluedog225
Texas
- Nov 18, 2019
- 2,970
Good evening.
I’m trying out various solar disconnects.
I’d appreciate some help wiring these din rail mounted breakers correctly.
I see that they are meant to be installed a particular way. As in, do not reverse feed.
I was planning on using them as a solar panel disconnect and I don’t understand how I would wire them.
For example, if I put them on the positive line, do I feed in through the positive side and out through the negative side?
Put another way. I don’t understand the positive and negative symbols on this. Is it intended to indicate direction of current flow?
Many thanks.
Many thanks.
