I have 2p4s 280 ah eve cells with chargery. Right now chargery is not fully setup because I ordered the ISO board and was sent power board. This all happened right before Chinese New Year so I couldn't finish setup. I also have a Thonewave labs Bluetooth monitor on it so I can see what is going on. It gives me voltage, current, power, power meter, and charge meter. Also has battery runtime.
I had to put battery into use Friday because we had planned camping trip. So far I'm really happy with the batteries. Has been a real learning experience. I have been on battery power only since Friday. I had TV on most of yesterday because we had 35 mph winds in the desert. So so far the Victron 3000 has been on the whole time. I could have shut it down at night but then I would have to setup the satellite everyime power is lost. Have ran microwave to warm things up. Heater runs a lot because it was down to 38° last night.
Now the problems
Has anyone had issues with not being able to shut off the BMS? If I hit the stop button it will not go to sleep. First I thought it was because it was cold. So I warmed it up and no different.
Second I haven't updated firmware. How much better is the accuracy when updated? Right now its garbage. Says I'm at 0 capacity and I was at 30% when I checked this morning. Don't know when it hit zero.
I'm having second thoughts about Chargery reliability. I don't know if I want to trust it with low voltage cut off. Right now I have charger set to 14 volts and does a good but I want the BMS to back it it also.
Here is a screen shot of Thornewave. I can be 100' away and still connected.
Now the problems
