Checkthisout
Solar Wizard
- Nov 14, 2021
- 4,821
So ongoing issues with this bms. The generator at the sight has failed and its winter so not enough charging.
Unfortunately I cannot make it out there until Friday night.
So as you can see, Discharge Mos is off but the bms shows a 70 amp charge even though no though no charging source is being supplied to the battery. The voltage readings are accurate.
