Thanks Dan, Guy was saying those big mothers of a battery are too big for the boat.. I have smaller EMC you could have I sent Guy a picMaxx123, That loos great
Typical electrition no round corners on the wire a perfect 90 degree, very nicePlease! I'll even pay for it. If you send one my way, I've got a 20A-300A individual 3.2V cell capacity and lifecycle tester I just built to evaluate the big blue 280AH cells from alibaba. I was in the process of evaluating several cell models from various chinese vendors prior to buying a bunch of them then I saw yours.
I'd LOVE to have a individual cell to test the snot out of.
Been waiting 3 weeks for my bms to arrive for the byd, Monday is the day, rivet them into place and get them off the kitchen tableTesting soon!
I have the second one, with the piggyback on it dbms max 10Ab, We know they came from solar farms. BYD does not have a great record on making electric buses. lots of problems, The farms went bankrupt, maybe from these strange boards, Nicely built, better than most you see out of ChinaSo the sticker on the side of the BYD BMS. Some of them are Active and some are Passive. Some do have a balancing board I am still looking at. It's odd because it defeats the isolation plugging in this balancing sub board. it takes external 12v to balance it wont activate on its own. So look at your BMS see if it is a P or A or just look inside...you know you want to. We should do a poll see what people are getting. Did these not all come from same project or is this design being offloaded on us because of a problem? Just to be clear we are getting these from what is a battery recycler / scrap dealer. I just find this a mystery, not that it matters...
Yay! Palleted up and heading my way monday. Mark sent this with an email. Oh my aching back.... Gonna have a heck of a time stuffing them all into this. Huge upgrade.
View attachment 3369 View attachment 3370
Edit: Just measured and they won't fit. Cabinet is 17" deep by 36 wide by 63 tall, bat modules are 23 x 18 1/2 x 9 1/2. Not sure what they are when stripped down. Really want them in a fireproof cabinet though. Wonder what costco has...
I only have one module but it has the p. It was purchased through tech direct club. also I was wondering if they all have the same model # ABSSM?So the sticker on the side of the BYD BMS. Some of them are Active and some are Passive. Some do have a balancing board I am still looking at. It's odd because it defeats the isolation plugging in this balancing sub board. it takes external 12v to balance it wont activate on its own. So look at your BMS see if it is a P or A or just look inside...you know you want to. We should do a poll see what people are getting. Did these not all come from same project or is this design being offloaded on us because of a problem? Just to be clear we are getting these from what is a battery recycler / scrap dealer. I just find this a mystery, not that it matters...
I have a dual board ( a "P") if anyone wants it to experiment with
i was looking everywhere for a 14mm battery clamp, then decided to bolt on terminalI have a simple cheap terminal that works...
NEGATIVE import car battery cables fit snug...
The nut side needs a washer, square preferably to get the clamp fully tight, but they grab fine as is.
wtf, where Ray going to put his shirts, Armark rental? from uniforms locker to BYD power storage, They are really flimsy constructed riveted togetherI'm thinking one of these...
May not handle the weight though.
Agreed, but the lower end has room for all 4 of my batteries, and I can use the center doors for slide out bms, charge controller and charge meters, disconnects etc.wtf, where Ray going to put his shirts, Armark rental? from uniforms locker to BYD power storage, They are really flimsy constructed riveted together
When I picked mine up they told me they cut the straps and cells immediately ”relaxed” and they could not restore to original shape.Maast, I think to remove the green strapping would be a bad idea. The whole pack is compressed and does show sign of a little bulging. I think releasing that stress is going to cause a ton more swelling. I think davepoz has a good way of connecting all the cells in P and just attach a single balancing bms to that. Id avoid the shielded foil wrapped wire however.
