Retailers may not say if the breakers are polarized.
On Midnight's web page, most of the DC breaker listings way polarized or not:
MidNite Solar Category Products.
www.midnitesolar.com
Here's one that does not. But at least the picture clearly shows "+" and "-"
MidNite Solar offers a large variety of alternative energy products from E-panels to charge controllers and inverters.
There ought to be a link for data sheet under "Documents" tab, but that has been broken for a while.
It also has a link to their tale of on-the-job learning regarding polarized breakers
The AC breakers of course don't say polarized.
If a DC breaker is polarized, it can only be relied upon to shut off with current flowing one direction, not the other. If the application can have current flowing both directions, a non-polarized breaker is required.
Between an inverter/charger would be one, of course.
Between a charge controller and battery is another, because if the charge controller fails current could be dumped into it from battery.
Between PV panels and charge controller is another, if there are more than two parallel strings of PV panels. In the event one PV string gets shorted, all the other strings will dump their current into it, reverse direction.
If OP's "1200 watt pure sine wave inverter" is just an inverter, no charger and no PV connections, then polarized would be OK.
