You can have various primary voltages.
13.2 kV primary is common. It should work in reverse but possibly at reduced capacity due to internal physical bracing designed for step down. But this could be BS rumor I read from a power company electrician.Those pad transformers require 19200 Volts on primaries to output 240 split on secondaries don’t they?
