Someone I'm helping might want to do compression lugs with THHN or XHHW.Why?
I'm skeptical of your claim.Fine Wire vs Coarse Wire are not the same when it comes to AC vs DC for Current Handling. Coarse is NOT recommended for DC. Think about it for a second, Why to High Amperage DC Welders use Super Fine Stranded Wire ? Don't cheap out on wire, there are consequences.
Yes and solid metal busbars seem to work fine for DC.Throwing gasoline on the fire here...
My welder does both AC and DC. It uses the same fine stranded leads for both. It's my understanding that the leads are fine stranded simply for flexibility.
I'm confused the charts are the same.This may be veering off topic but I looked at two bus bar ampacity tables, one for DC and the other for AC (pretty sure it's AC since it referenced 60 Hz). For the same size bus bar, the AC ampacity rating is much higher. I'm posting this mainly because I don't understand the difference.
AC ampacity table
Copper Ampacity - Eldre is now Mersen | Bus Bars
Conductor Size Calculating conductor size is very important to the electrical and mechanical properties of a bus bar. Electrical current-carrying requirements determine the minimum cross-sectional area of the conductors. Mechanical considerations include rigidity, mounting holes, connections and...www.busbar.com
DC ampacity table
Electrical: Bus Bar - Table 1: Ampacities
Ampacities in the table below are for bus bars having an emissivity of 0.4.www.copper.org
Que?
But same ampacity for same temperature rise for same dimensions.Not the same. Different websites, different tables.
Looks almost identical to me.This may be veering off topic but I looked at two bus bar ampacity tables, one for DC and the other for AC (pretty sure it's AC since it referenced 60 Hz). For the same size bus bar, the AC ampacity rating is much higher. I'm posting this mainly because I don't understand the difference.
AC ampacity table
DC ampacity table
