I am wanting to connect my Easun 5000-watt all-in-one solar inverter with AC input to take advantage of it automatically switching between PV or battery to Grid power when the PV or battery is unavailable. However, I'm a little confused about the breaker required according to the inverter's manual (see image below or PDF attached; I have the MLV-5KW-U model highlighted in yellow).
The inverter is only 120v, not 240v, and the AC input only has inputs for (see image below or attached PDF):
- one (1) live/hot
- one (1) neutral
- one (1) ground wire
