I am using Daly BMS with Bluetooth (only read, no write without PW as stated) I was able to load the software Sinwealth referenced earlier and I was able to change and write values to the BMS. In reading the values, however, I have some concerns as the BMS was intended to be for Lifepo4 and the BMS physically shows the correct labeling, however when I pull/read the values from the BMS it shows Device Chemistry as LION with Hex value for Battery Chemistry ID as 002F (no reference to know if this is correct for Lifepo4) I will look to see what parameters for charge and discharge should relate to Lifepo4 and see if those are correct.
