Yeah just spit on it first to make it extra stickyCan you use that stuff instead of mortar when making concrete block walls?
HahahahahahaMore like extra stinky
If you can still find a MC-3 crimper kit, there is a special expander for inserting the contact into the boot. Chances are, if you do find one it'll be too expensive to be worth it. Simply cut off any MC-3 connectors and crimp on MC-4's instead.I did install some MC3 on ends of PV panel wires that had been cut. It would help to have correct size contact for the wire gauge, and correct size boot for the insulation. I used wire lube but it was still tough. Someone told me soften them in hot water, will try that next time.
Here it isI was installing the panels to replace bad ones in an existing array. Sure, could make a transition and continue in MC4. But I've got over 100 panels (of two brands) with MC3 in a number of arrays. MC4 for another brand.
I like MC3 better, seems higher quality than rolled sheetmetal contacts.
I haven't found the boot stretcher for sale, but found a forum talking about it and a link to one in use:
I find many strip & crimp kits but no boot expanders. Didn't know they existed. Thanks for the tip!
Solar Panel MC3 & MC4 Crimping Tool Kits
Discontinued - Superseded by SPK-100 The Jonard Tools SPK-90 Solar Panel Crimping Tool Kit is designed to facilitate the installation and maintenance of solar panels. It includes a variety tools to make installing and maintaining solar panels quick and easy. This crimping tool kit includes the...jonard.com
That’s a great product for sure. Cyanuratic and superior to regular urethane caulking.that was a lesson in the tenacity of 3M adhesive-sealant.
So, when are blocking diodes called for in a solar build?"Reverse polarity protection"
If you hook 200V reverse polarity to inverter, it drives electrolytic capacitors backwards and they blow up. Maybe other things too.
A blocking diode could have held off the voltage, but would have voltage drop in normal operation, causing power loss.
A backwards diode across +/- shorts them out to about 1V or so under reverse polarity. That prevents damage.
This is one reason why there is a maximum Isc spec on MPPT inputs.
In the past, some brands of inverters didn't have the diode, and suffered near 50% failure during install.
This works well for PV, limited current. Not good for battery or AC powered DC supplies. Those may used back-to-back FETs. More expensive and limited voltage range. Typically also used to implement inrush limiting.
Wonder if these 20A MC4 with the diode would protect solar panel wires, like 12 awg, with lower ampacity from over-current from combined short circuit current that is too high due to parallel configuration, for example, three large solar panels in parallel. Here is some for sale:I'm not sure blocking diodes are ever needed.
Only if there would be excessive backfeed, which multiple parallel PV strings usually would not do.
In the case of a short circuit, fuse/breaker is supposed to protect (but polarized breakers might fail to do so). Diode, if it didn't fail, would prevent backfeed. I wouldn't consider a diode reliable enough for fire protection.
You can get "ideal diode" which is a MOSFET with drive circuit to avoid the 1 ~ 2V drop through a power diode.
If you get time could you check post #83 here: https://diysolarforum.com/threads/b...cks-with-two-8s-bmss.50986/page-5#post-651585. Is this a solution to an over-current problem affecting my solar panel wires?I'm not sure blocking diodes are ever needed.
So, the object is to protect that short run from the MC4 20A fuses to the combiner box and maybe add an MC4 blocking diode to the positive wires, or some kind of back feed protection. A second charge controller may be an option too.20A Fuse per string protects the wires from 37A. (except for short run from combiner box to fuse)
Diodes should protect wires from backfeed, but are not a UL listed part, could fail shorted in which case wires are unprotected.
