Systems Planet
- Jun 25, 2020
- 36
Just finished my Della install.
Took way longer than I thought it would.
I had to manufacture two connectors for the 240 volt lines. The connector on the unit is tiny. The wire I had on hand was 10 guage.
I had to manufacture a stand out of pressure treated lumber to sit in the grass.
Getting the unit through the tiny hole in the wall is a real pain. I never could get the unit to sit level on the wall. The pipe forces the unit higher on the wall on the right side.
Love the timer setting for starting and stopping the unit.
The unit was drawing 11 amps on high.
The outside unit is so quiet I thought it was off.
Overall very happy with the unit.
Installing the unit is not trivial.
Thank you Will for your excellent tutorial ?
