RCinFLA
Solar Wizard
- Jun 21, 2020
- 3,567
Yes, series stack the inverter with DB25 connectors series stacking control cable and both inverters to same battery. Battery charging should be set up the same on both inverters. Bulk current to battery will be double, half contributed by each inverter.I have 2 Trace sw4024 24v inverters same firmware revision but not installed yet. I do have an Onan QD 12.5kw generator with both legs fed to a 120v panel. I have a 50amp shore power cord connected through an isolator/switch/filter. I can get 120v to the panel from shore or the generator. But I want to get two 24v 200Ah LifePO4 batteries and install the inverters. Should I just parallel the batteries and stack the inverters? I downloaded a file that shows a connecting cable to stack the inverters. I really need some help such as a diagram. Thanks hopefully I need help.
I assume the DB25 series stacking control cable diagram is the one I posted before. Make sure the DB25 connector on inverters are cleaned and not filled with dust or bug droppings causing poor connections.
![Trace Serial Stacking.jpg Trace Serial Stacking.jpg](https://diysolarforum.com/data/attachments/136/136519-f36dbb95015c93f64787242a3ae67124.jpg)
