I am running two of my 12v devices directly to the inverter ring terminals. They're tiny (20awg wire). Is there a rule of thumb when I should be using a bus bar versus direct connect?
Do you mean you are using the inverter inputs to connect 12VDC devices to? Or are you referring to your charge controller?
Yes they should be fused and I’m a huge fan of those bluesea fuse boxes with negative terminal blocks. I feed mine with 8ga and fuse at 30A with a fuseholder like above (those fuseholders shrink in shipping from China. Mine are supposed to be 8ga but they arrive just slightly thicker than 10ga).
Anyways, I am uncertain how to answer you because connection of 12V things to 120V inverters seems - dubious.
