positive is recommended.Does it matter which side of the battery you fuse? + or -
Always the + unless for some reason it is grounded. Can't think of any reason it would be. But had to cover all bases. (Possibly an old European mobile installation)Does it matter which side of the battery you fuse? + or -
Convention is to fuse the + on a battery under 60V; high voltage batteries require + and -.Does it matter which side of the battery you fuse? + or -
Only exception I am aware of is -48VDC telecom systems.Always the + unless for some reason it is grounded. Can't think of any reason it would be. But had to cover all bases. (Possibly an old European mobile installation)
They ground battery + ?Only exception I am aware of is -48VDC telecom systems.
Overcurrent protection is always done on the ungrounded conductors.Not sure if I'm right, but I always thought the reason the (+) is fuse/breakered is to maintain the grounds as the (-) are grounded.
Yup'67 MGB GT. Positive ground system. Not that it's relative to this discussion, but oddball systems like that do exist. I had to be careful when getting a jump start from another vehicle.
Yup
That's why I covered my butt. lol
Yeah, something about limiting corrosion on long copper phone lines. Not sure why it is still done for telecom and radio equipment though.They ground battery + ?
That was interesting enough to make me look it up. According to the internet, it started as a way to limit corrosion, just as you said, because back in the Dark Ages a lot of wire insulation was cloth based, and corrosion was more of a problem for telephone lines. Apparently it's still being done because modern insulation greatly reduces the corrosion problem but doesn't eliminate it.Yeah, something about limiting corrosion on long copper phone lines. Not sure why it is still done for telecom and radio equipment though.
Here is what I'm referring too.Always the + unless for some reason it is grounded. Can't think of any reason it would be. But had to cover all bases. (Possibly an old European mobile installation)
