Docan "EV grade 304AH" test results and questions
SolarTruckCamper
Hello All,
Yesterday, I received my order of four "A304"s, which is what Docan calls "EV Grade" 304AH EVE cells. Date codes revealed the 4 cells were manufactured on 9/24/22 and 9/25/22.
Without balancing the cells, I hooked up the four cells a JBD BMS:
I then applied a load for about 5 minutes:
I've seen folks test individual cells and find wildly different voltage drops under load when cells are good vs bad. Are the results I'm seeing rendered irrelevant because the cells are wired up into a pack? If not, this looks good, correct?
At 50A you probably have about 10 millivolt drop from bus bar and terminal compression connections between cells.
The raw loaded slump from rested no-load OCV is 1) 68 mV, 2) 70 mV, 3) 68 mV, and 4) 65 mV.
Subtract off 10 mV for bus bars, yields about 58 mV which is pretty good terminal voltage slump range for 50 amps. Also pretty well matched.
I would trust a good DVM reading directly on base of cell's terminals over the BMS readouts.
Hello All,
Cool, how do they look like and what setup are you using?
