Alkaline
Solar Wizard
In my RC car days once a lipo fell below 80% it would rapidly fall to like 5% within 10 - 15 cycles. Its not a gradual decline, its a fall off the cliff drop.
thank youIn my RC car days once a lipo fell below 80% it would rapidly fall to like 5% within 10 - 15 cycles. Its not a gradual decline, its a fall off the cliff drop.
That’s the usual failure mode. If you use your cells conservatively you will prolong the failure.why 80% of original charge capacity, is my curiosity.
dendrites might have formed?
Do the FET's always fail (weld themselves together) Closed, or do they sometimes fail Open ?From a diy standpoint, what is the warranty on your BMS?
Your cells might be fine for 4 years, but then one day a fet in the bms welds itself in a closed condition, and takes a cell down to zero behind your back. You replace it, but that one is 4 years younger.
Or, your power needs have increased, and you buy another system anyway. I suppose you could tack on an addition that is 4 years newer, but now always keeping an eagle eye on the others...
On the road to a franken-bank when you consider possible failures..
Like solid state relays they typically fail closed... typically contacts of any type dont stick and weld themselves to nothing so it only makes sense they would typically stick on. If the failure was catastrophic ive seen the circuit open back up but ive seen most mosfets stick closed.Do the FET's always fail (weld themselves together) Closed, or do they sometimes fail Open ?
Lipo is the same as Lifepo4?In my RC car days once a lipo fell below 80% it would rapidly fall to like 5% within 10 - 15 cycles. Its not a gradual decline, its a fall off the cliff drop.
FET's are not relays. I think they generally fail open, there are no contacts in a FET. I think their semi conducting material burns open.Like solid state relays they typically fail closed... typically contacts of any type dont stick and weld themselves to nothing so it only makes sense they would typically stick on. If the failure was catastrophic ive seen the circuit open back up but ive seen most mosfets stick closed.
I understand they are not mechanical relays but they are both forms of electric relays/switches. (there are no contacts or moving parts in a solid state relay either)FET's are not relays. I think they generally fail open, there are no contacts in a FET. I think their semi conducting material burns open.
I was second guessing my own memory.. I do think it depends on the mosfet and circuit though. I can think of a certain series of sanyo tvs that had a common mosfet failure that would open the circuit and cause no audio on the tv... I probalby repaired a half dozen or so with that same failure.I replaced lots of shorted out power MOSFET's, the only time it is measured as open circuit is when the die is blown into pieces.
How and when MOSFETs blow up - Power Electronic Tips
www.powerelectronictips.com
FETs are semiconductors designed for controlling large amounts of current. The physics of how this is done means they are much more likely to fail as a short.FET's are not relays. I think they generally fail open, there are no contacts in a FET. I think their semi conducting material burns open.
So again, how does it apply that if a LiFePo4 cell is at 80% capacity, it is considered trash and capacity will fall off the cliff same as you’re LiPo cells?Nope, different types of cells. LiPo are the 3.7V high current cells. They are usually used for RC models. And usually these are pouch cells packed in 2S-6S packs and rated for high current in the 20C - 40C range. These are the "dangerous" cells.
My first cells were LiPo 3S 2200mAh rated for 20C. The brand was Turnigy. They were used for 8 or 9 years as a power source for DIY camping lamps. Each year they got 10-20 cycles discharged to below critical levels (8.5-9 volts). Last year I got rid of them. They were badly swollen, but still, they were pulling very close to the initial capacity.
No lipo is lithium ion polymer it is 3.7 nominal and 4.2v fully charged. It has the highest energy density but also most kaboom potential.Lipo is the same as Lifepo4?
Kinda apples and oranges, no?
Generally used in phones, thin laptops, and rc planes and cars.
Threy can have discharges of 20-70c so huge energy bursts.
How have you been seeing LiFePO4 fail?So again, how does it apply that if a LiFePo4 cell is at 80% capacity, it is considered trash and capacity will fall off the cliff same as you’re LiPo cells?
I don’t think you can apply LiPo experiences/expectations to LiFePo4 cells.
