Old_Skewler
I am trying to understand whether I can connect my newly installed EGC (solar racking ground, charger controller ground and inverter ground) to the existing AC grounding that currently serves the cabin OR if I need to install a new grounding rod system.
This is for an off-grid installation. The baseline is a cabin with a generator and two rods dug into the ground a certain distance apart - I paid a local electrician few years ago to properly dig the rods and run the ground conduit to the main panel. This part is done.
Now I am wrapping up the solar installation and I do not know whether the new EGC ground wires from the solar racking + charger controller + inverter should also connect to the existing AC ground circuit OR if I need to install a new set of grounding rods for the DC equipment.
Any feedback on this question?
TIA!
TIA!
