Partimewages
Isn't that the way its always been?
Wouldn't have needed to if they hadn't run utility prices out of control with disposable renewable tech. Could be doing another hobby.If it hadn't been done, you would most likely not have the opportunity to go off grid with a solar system of any size with today's prices.
Usually although there was always opportunity for the little guy during some periods.Isn't that the way its always been?
You should stay completely on grid power.Wouldn't have needed to if they hadn't run utility prices out of control with disposable renewable tech. Could be doing another hobby.
I would if that were true, but my electricity cost in the $.30-40 range thanks to energy policy in California.You should stay completely on grid power.
If you are only interested in energy cost, renewable isn't for you.
That is easily fixed, move out of CA. Choosing to live in a fascist state has consequences. https://diysolarforum.com/threads/m...tall-and-electrical-devices.75118/post-955044I would if that were true, but my electricity cost in the $.30-40 range thanks to energy policy in California.
I live in an area where just a few years ago the average house cost about one year's earning for the average worker.I've thought about it a lot. But the benefits here outweigh the cost.
@glandpuckNot required by NEC.
Just because your AHJ is ill informed or ignorant does not change the NEC.
Yes1. can it be the twisted type ?
No2. does it have to be bare?
Awesome.Yes
No
I don't run bare copper for anything but a swimming pool perimeter.
My panels will be positioned closer to my neighbors house. Even if ground resistance protected my house a ground rod pulse to their electronics would not foster good relationships. Reason I will be upgrading my waterline grounding system (1980s build hence grandfathered) to also bond to the two exterior ground rods where everything will tie in.In that case. You should erect a fence around the array. And add danger signs. So that people are warned to stay away.
I'm not sure what you are talking about. There shouldn't be any connection between your system and your neighbors. Other than possibly the utility connection.Even if ground resistance protected my house a ground rod pulse to their electronics would not foster good relationships.
It would not affect your neighbors. Unless you also connected your array grounding to theirs.Sorry. Please let me reword.
If I were to sink a separate ground rod by the panels not only would a fence be advised but I was concerned about the chance of a ground pulse to my neighbors house.
