I should know this....but I am coming up blank. My system, 24 VDC, currently (pun intended I guess) uses a dump load, a 1000 watt bank of resistors, and a 60 amp MorningStar PWM controller/ load divertor that decides when to divert incoming power to the dump load. and has for years, mainly to keep my grid tied hydro under control when the grid goes down. It has worked fine for 15 years, in the rare times and for short periods, the grid has gone down here.
But I recently added a additional, winter time only use (when the hydro is down) 1000 watt PV array to my existing PV array, again, all grid tied via a Outback inverter and a token /minimal battery bank. Now I am putting out as much as 105 amps, obviously in excess of what my divertor AND my resistor bank can handle, but the difference is, unlike the hydro's input, which goes right into the battery bank, the PV arrays first go thru a charge controller, 2 actually. So....., if the grid goes down (which I replicated this morning by throwing a breaker) will the controllers continue to allow incoming power to the battery, overcharging it in short order, frying it (sealed AGM types)? Or, will the controllers "control" the voltage rise by the removal of the load, by shunting the power away before it reaches the batteries?
My normal voltage, which is the voltage the batteries float at, any excess being sent into the grid, is 26 volts, it went up to 30 instantly, and of course the resistors started heating up. At this time of the morning, the system was only producing 55 amps, about half of it's max.
A fix, if one is needed is another dump load and another divertor. Another fix, if for the grid not to go down, at least during the day, but that's wishful thinking of course.
