Cascade1911
#8 is L08. Tried 37 to 27.0 and 27.8. No change. I changed #3 to APL, no change.
Setting #14 controls setting #4. #14 must be a minimum of .2v higher.Anyone know why I can't go above 20.8v on #4 I can go lower but not higher. I think when I first got my hands on it it was 23v then I set it lower and I was stuck. I tried using the PC software as well unless I don't have the right one. It's that setting and the switch back to inverter setting I can not change. I want to get new batteries because mine are toast and 20.8v is a little lower than I'd like for it to tigger the generator to kick in.
Awesome thanks good info can't wait to try. With the monitor software I was trying the change the same way not knowing 14 was affecting it. I will report back once I get back to my camp. I close to getting to try out my DIY automatic start for my generator using a PLC and solidnoid for the choke and connect it to the dry contact off the controller.Setting #14 controls setting #4. #14 must be a minimum of .2v higher.
BTW #35 affects #5 also.
When you say you tried using the monitor software (v1.6) at what point did you have dificulty?
Got it working. Need to making my PLC know the generator doesn't start and to retry if it fails but other then that it works. Though when the generator does kick on and charge th batteries setting #6 tells is when to kick off the generator and go back to the inverter, yet there are different phases for charging the batteries. If I select 29v it gets to only a certain percentage then it switches to a lower charging voltage. But at that point the generator is off and the batteries are not fully charged....Awesome thanks good info can't wait to try. With the monitor software I was trying the change the same way not knowing 14 was affecting it. I will report back once I get back to my camp. I close to getting to try out my DIY automatic start for my generator using a PLC and solidnoid for the choke and connect it to the dry contact off the controller.
Sorry to hear about your troubles with the Anenji. Yeah your expereince would be better off posted as a Thread to "Solar Equipment Vendor Review Corner".Not sure if it fits into this thread, a warning on Anenji Support!
Thanks for the advice, I was unaware that there is already a "Complaining" thread, I have put it into:Sorry to hear about your troubles with the Anenji. Yeah your expereince would be better off posted as a Thread to "Solar Equipment Vendor Review Corner".
Anenji Support
This is my support experience with an Anenji AIO: I installed an Anenji MPPT 3.6KW Off-Grid Solar-AIO 100A Hybrid 230Vac 24V 500V in June 2023 with 2 kW Solar panels and 1,5 kWh battery to charge a hybrid EV in my garage. However whatever the settings the inverter turned off after less than...diysolarforum.com
Has anybody an idea what to do with broken equipment for which no support and no spares are available?
Kind Regards, Anenemy
