Date: 2020-01-20 09:57
To: Ecoflow Support;
EcoFlow
Subject: Refund or Exchange
I am in receipt of (2) 1300's; Backer # 1,177.
I have tested them round-trip, and find them way out of your claimed performance:
First, fully charged, both were put on a load and ran until shut-off occurred.
#1 outputted just .57kWh. If all 1,295 Wh were used, that is an inverter efficiency of only 44%
#2 outputted just .58kWh. If all 1,295 Wh were used, that is an inverter efficiency of only 44.7%
(Chances are the Delta shut down before using all 1,295 watts, so the above numbers would be even worse.)
Next, fully charging:
#1 took 1.64kWh, for a charge efficiency of only 78.96% (Like putting $1,640 in the bank, and having only $570 available.)
#2 took 1.68kWh, for a charge efficiency of only 77.08% (Like putting $1,680 in the bank, and having only $580 available.)
Round-trip efficiency:
#1 34.75%
#2 34.52%
I build Solar Generators, and have also tested many brands. These numbers are the absolute worse that I have ever seen.
To be clear, you said in the Comments Section that the AC outlet efficiency is up to 92%
I either received two faulty units, or, this is the actual design of the Delta. If this is the actual design, I want to return them for a refund. If you believe they can do better, please advise.
Awaiting your response.
Joseph
EcoFlowCreator
4 months ago
Hi Jose,
DELTA's AC outlet efficiency is up to 92%. Thank you for your advices for the 12V port. I will definitely forward your idea to engineering team. We will keep upgrade our product.
EcoFlowCreator
4 months ago
2. Efficiency:
a. AC to DC/DC to AC: up to 92%
2. USB- A: 95%
3. USB- C: 93%
