k490
What is the max current draw for the inverter on the Eg4 3000 ehv-48. The specs only show the max charge current of 80 amps. I want to size the DC fuse properly I was going to use a 100-amp fuse that would give me 4800 watts. I will be putting together 280 amp DIY Lifep04 battery bank when they arrive from China.
https://eg4electronics.com/backend/wp-content/uploads/2022/07/EG4-3000EHV-48-Spec-Sheet.pdf
