EG-4 3000 ehv-48 Max inverter current
k490
Phoenix, Arizona
Since the inverter is 3000w the math would say 3000w ÷ 48v = 62.5amps. But I would imagine you have a common port BMS so charger and inverter will use the same wire. And the charger is 80amps. So the 100amp fuse will be fine.
That's what I was thinking just to keep a fire from starting seems like been number of threads here with inverters catching fire after something shorts out want to keep the fuse as close to max power as I can.
