EG4 18kPV Q+A general thread
Is the wifi dongle not included with the 18kpv
It is included and if you are asking because it lists "optional" underneath it I also sent email to Signature Solar that that is confusing because people might think it is not included simply using the term "optional" under the picture of "what is included".
Update: Installed inverter last week and hit a dead end with user registration. Gilbert reached out to me with what appears to be an incorrect registration code. Then Travis from Signature Solar messaged with another code and asked for my contact info, to which I immediately responded. Within an hour I received an email from Sean:
To which I quickly responded minutes later with all pertinent information.
And here we are Monday and I've heard absolutely nothing back from anyone.
I'm REALLY trying to remain positive, and not bash anyone here, but seriously guys, this is testing my limits quickly. Spending many thousands of dollars on a piece of equipment to then have zero ability to use it with something as basic as user registration. Then to be told "they will do it for me", which absolutely should not be required in any way, and to not hear back for days on end to the point that I use a forum to hopefully get a response??
I've literally had MORE communication from members reaching out to me via private messages than I have from the company, I'm really beginning to feel like taking a chance and saving a bit of money on the EG4 was a mistake over a Sol-Ark at this point. Saving money sounds great, but at some point you have to question these things.
I had exactly the same issue. I was able to install the inverter, only to find out that it doesn't work with EG4 LiFePo4 batteries unless you update the firmware or dish out more money for the ugly communication hub. Signature Solar really failed in communicating any of this information. The 18K inverter itself is awesome!! but the WiFi setup is horrible, I can't even get the dongle to broadcast a hotspot, it's completely broken. I called Signature Solar tech support and they said they would create an account for me !? How does creating an account on the backend resolve a faulty hardware device !? It would great to hear from the company as to what specific steps they are taking to resolve the horrible customer experience.
There is a lot that you learn after you purchase one. Nice unit but needs a lot of messing with and internet is practically mandatory.
they must not have gotten the point, will push for review
Well if it needs to be plug in on the side, mine did not come with one.
The manual shows picture of everything that is included and the wifi dongle comes in a small white box alone. I believe it was right on the very top by itself on top of the foam. Unless you opened the box upside down in which case you might have missed it?
Mine came inside the main box of the inverter. It is a small white box that only holds the dongle with a number on a white sticker posted on the side with the s.n./ pin no. / and a scan logo. Instructions in manual as well as watching a few you tube videos before I bothered. After the second try all 3 lights came on. I've never had to reset it at all. I can turn off my Wi-Fi in the house or on and it reconnects on its own. The hardest part for me was getting my setting right in my home Wi-Fi box for communications. Unless you have those setting right you will not get the 3 lights to come on.
Hello all. I'm reaching out to see if anyone can help with a few things. I've talked to both SS as well as a tech from EG4. Both have remoted into my unit with no luck. I'm not sure who the tech was at SS.
I have the 18K with 6 Lifepower4 and 2 LLv2. LLv2 are #0&1 in the stack and the rest taking up 2-7. Inverter is not whole house, only running some loads currently. Mainly both AC's and some 20a circuits covering fridges and freezers for now. I have just under 11k of panels that on a good day produce right at 50Kwh of power ( at least it did yesterday) and that is enough to run what is connected as well as charge the bank to full. The latest firmware has been applied to both the inverter as well as the Lifepower4 batteries.
Currently my issue is that If I turn on the Grid connection, everything runs off the grid and uses none of the solar or batteries. I've tried several different settings including turning everything to disable. I was told at first from the tech at EG4 that the solar should pick up the loads after 5-7 minutes, no luck. At the moment my work around is to manually turn the grid on as the sun is going down to get the house down to the temp we want ( roughly hours ) and then turn off the ac's, cut the grid to get everything back to solar and then turn the ac's back on so the batteries are used at night to cool the house.
To my understanding, this inverter should be able to run the loads from Solar first, Battery second and if those are not sufficient the Grid would kick in and take over the rest of the night until solar started to come back in the morning. Any help with this would be appreciated.
Can I live with manually turning on and off the Grid, sure. Would I like it to function as advertised, would be great.
Other than this issue, this inverter is on a completely different lever from the 6500's.
As far as the Wifi dongle, it is in a small white box on its own. I would have missed mine if I wouldn't have taken everything out of the box.
This sounds similar to what @rmacgurn was having https://diysolarforum.com/threads/eg4-18kpv-q-a-general-thread.61636/post-834385
and I lost what solution there was if there was one.
I would say yes but mine doesn't use Solar or Battery at all if the grid is activated. Once the Grid is turned on, I can hear the transfer switches kick in and from then on the only thing the Solar will do is charge the batteries. Nothing is powered from Solar or Battery once that happens.
In other words, I shut everything down. Turn on the batteries one at a time, kick in the PV, turn on the Grid and then turn on the inverter. Everything runs off of Grid no matter what settings I turn on or off. The only way I can get anything to run off Solar or Battery is to shut down, restart without turning on the Grid supply breaker and good to go until the batteries are dead ( or close to it).
What firmware version is your 18kpv running?
Can you share your settings? Use the website to share is the easiest to get them all on one screen.
Firmware was updated yesterday to FAAB-1110.
Looks good.
Have you tried clicking the restart inverter?
Off topic...if you have your 18kpv always grid connected...you should enable AC charge, Use SOC, Set % 3-5 above on grid cutoff. 1691261285820.png
Inverter typically picks up the load using Solar and Batteries automatically.
Occasionally I've seen a 5 minute delay, but I haven't noticed that in a while.
Can you share the main LCD display and battery status screen?
Looks good.
Off topic...if you have your 18kpv always grid connected...you should enable AC charge, Use SOC, Set % 3-5 above on grid cutoff. View attachment 161229
Side question: how are people connecting battery cables? You can't use finely stranded cable or even compression lug on cable because it uses screw lugs for all power connections.
Connect the CTs
WHAT IN THE LITERAL ************!!!!!
I feel like a complete MORON. Good thing I didn't throw the box away. I had no idea that CT's came with it. Like an idiot I glanced at the content list in the manual but since I thought you only needed CT's for exporting, and I wasn't exporting, I #1 didn't need them and #2 for some reason thought it said optional under them in the contents list.
Found the box, hooked them up and like magic, all is right in the world. Now I have a question for you. How is it that someone from SS and EG4 couldn't see that and with a few pictures you found the issue?
I wanted to ask for everything at once, figured I'd look at the settings first then move on to the physical setup next.
FYSA @Markus_SignatureSolar
How have you not exported anything?! Wish I had an answer for you. I cant keep mine from charging battery. My unit is very grid preferred. My solar jumps all over with grid connected. Its stable with grid off.
If you mean export to the grid, I don't have an agreement with the power company. Last thing I want to do is give them power for a small price, have them mark it up and sell it to someone else. Might be a different story when I get to the point of having enough battery backup and large enough array to sustain my entire home. Until that point I'm going to be a bit selfish and keep it all to myself.
Keep an eye on the export...in my opinion anything under 1kWh a day should be fine...assuming you are also importing a similar amount. If exporting becomes an issue ask SS to install 1111 firmware.
