Zapper77
Renaissance Man
- Jul 23, 2022
- 2,343
If you connect the grid right now what would happen?I have. I’ve also done a complete shutdown and restart .View attachment 161237View attachment 161239
Connect the CTsThe Grid takes over everything, solar charges the batteries. Never changes back over to Solar or Battery....I did that about 20 minutes ago.
How have you not exported anything?! Wish I had an answer for you. I cant keep mine from charging battery. My unit is very grid preferred. My solar jumps all over with grid connected. Its stable with grid off.I have. I’ve also done a complete shutdown and restart .View attachment 161237View attachment 161239
WHAT IN THE LITERAL ************!!!!!Connect the CTs
I wanted to ask for everything at once, figured I'd look at the settings first then move on to the physical setup next.WHAT IN THE LITERAL ************!!!!!
I feel like a complete MORON. Good thing I didn't throw the box away. I had no idea that CT's came with it. Like an idiot I glanced at the content list in the manual but since I thought you only needed CT's for exporting, and I wasn't exporting, I #1 didn't need them and #2 for some reason thought it said optional under them in the contents list.
Found the box, hooked them up and like magic, all is right in the world. Now I have a question for you. How is it that someone from SS and EG4 couldn't see that and with a few pictures you found the issue?
If you mean export to the grid, I don't have an agreement with the power company. Last thing I want to do is give them power for a small price, have them mark it up and sell it to someone else. Might be a different story when I get to the point of having enough battery backup and large enough array to sustain my entire home. Until that point I'm going to be a bit selfish and keep it all to myself.How have you not exported anything?! Wish I had an answer for you. I cant keep mine from charging battery. My unit is very grid preferred. My solar jumps all over with grid connected. Its stable with grid off.
Keep an eye on the export...in my opinion anything under 1kWh a day should be fine...assuming you are also importing a similar amount. If exporting becomes an issue ask SS to install 1111 firmware.WHAT IN THE LITERAL ************!!!!!
Will do. Thank you for saving the day. I appreciate it.Keep an eye on the export...in my opinion anything under 1kWh a day should be fine...assuming you are also importing a similar amount. If exporting becomes an issue ask SS to install 1111 firmware.
I did one set of battery cables with ferrules and one with just strands. I personally prefer the ferrules. Just use a torque device so you get a good bite on the ferrule. Ferrules that I use are thin and easily deformed under the pressure, while still keeping the strands contained.Side question: how are people connecting battery cables? You can't use finely stranded cable or even compression lug on cable because it uses screw lugs for all power connections.
Wondering, what size battery cables you have in your KPV connection ?Side question: how are people connecting battery cables? You can't use finely stranded cable or even compression lug on cable because it uses screw lugs for all power connections.
Please share screenshots of your settings and CT sensor wiring.Any way, other having SS upgrade my firmware, to get this thing to stop exporting?
Disconnect grid connection...assuming you still have fast zero and disable grid sell.Any way, other having SS upgrade my firmware, to get this thing to stop exporting?
I do. I was thinking of setting times ac charge at 100w during the day and see if that alleviates the issue.Disconnect grid connection...assuming you still have fast zero and disable grid sell.
As shown on your post here.
EG4 18kPV Q+A general thread
Did you format the stick with the exact DOS commands ? I put the folder and a set of the files in the root of the drive too. Did you disconnect all power, PV, battery and grid ? Didn't use DOS commands. Formatted with both pc's. Thought about partitioning to a smaller size. Think I'll run by...diysolarforum.com
Nope. Grid killed for now. Frustrating but I’m sure there’s a solution other than this ….I hope.I do. I was thinking of setting times ac charge at 100w during the day and see if that alleviates the issue.
Pm me so I can help you outNope. Grid killed for now. Frustrating but I’m sure there’s a solution other than this ….I hope.
Only had .2Kwh export yesterday, today is 1.1Kwh so far.
I’m on with luxepower now. Will let you know how it goes. Thank you.Pm me so I can help you out
