I only have arrows on the CT's that were in a small white box. as for messing with the pin out to determine which is which I have no interest as mine is working fine without the reverse feature enabled. my issue earlier when I first changed it back and then saw it back to enabled as reverse was my bad, I restarted before hitting the set button or before it said ok saved. so it reverted to the prior setting was not the fault of any SS tech.
I am leaving early to go to the northern beaches of Costa Rica with my son so if I have time before we roll out I will post the graph of how it shows the energy coming from the grid and zero export. today as I showed it showed 1.8kw exported with the box for CT reverse checked. as I also said early on in CR the 3/0 and 4/0 runs from street are always black often the neutral is too but has some white tape on it, there is not tape on the other two lines. I simply pulled left and right feed from my main 200amp panel and used those as inputs to the left and right side of the invert AC input, then inverter used same two new 3/0 runs to go back following the left and right protocol so it did preserve the L! & L2 locations. anyway I think we can conclude that using that reverse option doesn't swap L1 and L2 but the CT direction. below is how it is running now.
