Just thought I'd pass along my latest testing. My unit has been running flawlessly, except for the firmware updates. It always shows 'failed update'. So I decided, if it's working well....why worry about it.
I've been running most house circuits off it (with a large battery bank) and 7.6kw of solar.
My big unanswered question was....will it run a standard 3 ton house AC. And what would the start up Amps be, etc? So today, I temporarily pulled the 3 ton wires off the main house panel and used a wire nut to jump it to my solar sub panel. It was a 30 amp breaker and I didn't have the right length of 8 gauge, so I went with 10 gauge for a short 3ft run. I was charging the car on a level 2 charger, so I turned that off to give the inverter the best shot at starting the AC.
Turned the thermostat down to see what would happen. Granted, it was in the middle of the day and I was making 5-6000 watts per hour of solar.
AC surge was 56 amps at start up and then settled into 7.1 continuous.
The inverter did absolutely weird and just kept running. The fans didn't even kick in. I was pretty impressed. Then I thought 'why not push it a little more'. I added the car charger back in at a steady 16 amps. Still nothing happened, it just did it with no issues. Fans stayed silent since I was right below that 6000 watt threshold.
I must say, this unit just works. Exactly what I needed.
