Samsonite801
Solar Wizard
- Oct 15, 2020
- 2,994
When all just shut down, the only sound was 1 of the 3 battery breakers switching off.
Do you happen to have a generator, and can make a cord to plug into your AC input?
As Adam indicated before, can you check voltage right at the battery lugs on both inverters. Also check for PV voltage right at the PV inputs, if all else fails, wire in a generator on the AC inputs.
If battery voltage is at the inverters, then will they turn on with the push button in?
