I've got a single 6500ex with 6kw of pv feeding into it. I'd like to max out the input of the 6500ex, which is stated as 8kw. What would happen I installed closer to 9kw of panels (because I have extra laying around)? Would it cause problems with the 6500ex or would the 6500ex just throttle the input down to 8kw? My thinking is, if I add extra panels above the stated limit, on days when there's clouds I'll have "access" to more because of the oversized panel strings.
Am I on the right track or should I definitely not install more than a total of 8kw of panels?
