I just tried out my new Chargeveter last night and it's not working as expected. I hooked everything up, started the generator, went to the Chargeverter and saw that the screen was powered up and it was reading the Battery voltage correctly at 50.4 V. I went into the Settings screen and set it for Voltage: 55.0 V and Current: 35.0 Amps. and hit ESC to return to the main screen.
I flipped the breaker on the Chargeverter and the generator engine changed tone (as if it had a load on it now) but the screen on the Chargeverter continued to show the correct Battery Voltage but showed Current: 0 A and Energy: 0 kwH and they never changed.
I got my clamp meter and put it around the cable b/t the Chargeverter and the battery and it read 37.4 Amps. It was charging the battery but it did not register that on the screen. Has anyone else had this issue?
