I have my chargeverter with proper pin out (as shown in the instructions), and showing 240volts both externally (via the outlet I wired) and internally (i opened up the chargeverter and measured it.) Running off a 5300watt Westinghouse 240v generator. I am following the start up instructions.
The problem I am having, is when I set the Amps to 100, it gives me 50amps (verified though amp meter)…. And when I set it to 80Amps, it automatically switches it to 40A… 30 gets 15…. And so on… there is no way I can get more than that?
HELP!
HELP!
