Adam De Lay
Solar Wizard
I'm not familiar with the settings of the 18kpv, but is it possible the values used to switch between battery/grid are set to closely to each other so it's constantly switching back and forth?
What did you have enebaled or disabled at the time this started happening?You usually have the answers to anything i post, so that worries me that you dont know![]()
No but his grid settings could be off (unlikely)I'm not familiar with the settings of the 18kpv, but is it possible the values used to switch between battery/grid are set to closely to each other so it's constantly switching back and forth?
Yeah, the odd thing is (unless the screen doesn't update fast enough), his grid values seem constant. The other odd thing is it looks like the inverters not showing any load on the system (unless I'm looking at this all wrong)?No but his grid settings could be off (unlikely)
18Kpv let's you set grid tolerance for volts and hertz high and low
I wonder where the CTs are located.Yeah, the odd thing is (unless the screen doesn't update fast enough), his grid values seem constant. The other odd thing is it looks like the inverters not showing any load on the system (unless I'm looking at this all wrong)?
Yeah, lots of unknowns.I wonder where the CTs are located.
The main screen is slower to update 1-3 second delay. He can click on the GRID and/UPS screen for more real-time information.
View attachment 175187View attachment 175188
Is it only working because he's still in "off grid" mode?His system shows to be running fine now. I want to know how this situation was created
Are you able to review the data logs for grid input during the time the issue occurred? (Understanding the 5 min data limit)His system shows to be running fine now. I want to know how this situation was created
Obviously solark /sHis system shows to be running fine now. I want to know how this situation was created
Those are some significant voltage imbalances between the two legs.I was able to pull these files looks like this was when it was happening but still need Raki to confirm
Thats why im asking about the Neutral being connectedThose are some significant voltage imbalances between the two legs.
Is Dominican Republic a 120/208 60hz country?I was able to pull these files looks like this was when it was happening but still need Raki to confirm
Its a 120/240 60hz just like USAIs Dominican Republic a 120/208 60hz country?
I know i know. Its a temporary EV charger, its not the best way but im sure thats not the reason… ive been using it since day one and charge daily. But ill take it off tomorrow and feed it from the breaker panelNice double tap.
Looks like it has maybe one neutral connection.
Reviewed several times. I only see one neutral connection and both loads have a blue double tap.
Do i need to have more than 1 neutral connection?Nice double tap.
It would be best to have over Current Protection for EV charger.I know i know. Its a temporary EV charger, its not the best way but im sure thats not the reason… ive been using it since day one and charge daily. But ill take it off tomorrow and feed it from the breaker panel
One from grid and one for subpanel. The one neutral that is visible in you video, where is it coming from? Grid or subpanelDo i need to have more than 1 neutral connection?
I made a compilation of short videos from last night. Uploading nowIt would be best to have over Current Protection for EV charger.
Can you reduce the EV charging rate to 40 amps? BTW the 18Kpv has a nice surge capacity with solar.
