Awesome!!!
?Been a bad few days for PV, batteries have been drifting away from each other and my OCD got the better of me.
Set the inverter to charge at its maximum 12kW, pushing 220A into the battery packs with no help from solar.
I've only tested inverter generators on my 18KpAre there any requirements on what kind of generator you hookup to the EG4 18KPV to charge the batteries? I have a DuroMax XP13000EH and the output is not pure sine wave.
Saw this update in the app while I was on the road working. Get home to install it and my app now says its xx12 20230801.
Fair - although I was excited.I had them Pull it until We test it
No grid connected to my system.Micro Grid is for connecting your generator to the grid ports if you dont have grid available.
But if you have a generator tied to your generator port. It will not turn the generator on as long as Grid power is on. I hope this helps
Are you wanting to tie smart load and generator to the same port? If so you dont you just put the generator on your grid port if you dont have grid? You cant share that port its either Generator, AC Couple, Or Smart Load
Cool.You will not back feed your generator. We actually tested this not to long ago sorry for the confusion. Pv or battery will not supply loads while the generator is on. Pv will help charge batteries but thats it.
What firmware are you running?It was a great run… I’ve had 5 days with this random craziness, cant reach signature solar
Have any of you seen something like this? It has done it during the day with 99% batteries, and 10,000-12,000w of solar
Its done it with no solar at night, with 90% battery
No detected patterns. Random
Any advice from you guys?
What happens when you turn the grid off?It was a great run… I’ve had 5 days with this random craziness, cant reach signature solar
That is some crazy sh!t.It was a great run… I’ve had 5 days with this random craziness, cant reach signature solar
Turn on more loads.Any advice from you guys?
Looking at your past post, are you still running early 0E0E firmware?It was a great run… I’ve had 5 days with this random craziness, cant reach signature solar
