ArthurEld
Solar Wizard
And another thing, if you stack the cells flat, the lower cells already have compression.
Stick that in the calculation
This is good to know, and seems like it will simplify implementation.Keep in mind that the spring pressure will not change unless it’s spring bound or loose. If you set the pressure to 12psi with compression springs and they stay in their range you will have 12psi across the SOC range.
As the cells expand the springs will apply more pressure and as they contract they will apply less pressure.
Sounds expensive. But ok.A linear spring will exert the same pressure as it is compressed slightly.
ie, if you get a 5kg spring and press on it against a scale the scale will read 5kg all the way until it is fully compressed.
Anyway got a hypothesis on why their is a difference between the top and bottom?I've just done a capacity test on each cell, and at the end noticed the the bottom rods were loose by 1mm or more, but the tops were still tight.
Total shot in the dark:Anyway got a hypothesis on why their is a difference between the top and bottom?
Gravity pulls more of the electrolyte to the bottom of the cell, so the bottom experiences slightly more expansion/contraction as the cell is cycled.
Yeah, well, 99% took about 6ah of charge while parallel top balancing 4 cells to get to 3.65V and 0amps. Ongoing discussions with Amy's replacement at Xuba.Charged to 100 %?
Concave sides will not matter much because as long as the cell isn't swollen the force will mainly be exerted on the cell periphery as it's the only part really rigid. Then when the internal pressure rises the side will unconcave and make contact with your clamping plate.
WILD SPECULATION FOLLOWS:Unfortunately my cells arrived charged, so had no choice with first clamping.
I would say the bottom swelling is to do with the cell sides not being flat. I can see daylight through the gaps in my clamped cells, and the top plates are a little wider than the area of cell under it. Thinking about it, the fact that many people have cells with undulating sides and concave areas, this will massively affect the usefulness of clamping.
It also makes me wonder if this is anything to do with why these cells are cheaper.
Would damage not be occurring in the cells swelling to fill the gaps? Some are substantial.
Possibly, sounds an expensive process. More likely that engineers like to play with ideas, and if they have big contracts to cutting edge purchasers, that would be valuable in house specifications to be able to supply. As much as we see lots of sub standard articles from China, these battery manufacturing facilities are state of the art, and probably involve a lot of in house dev and testing.WILD SPECULATION FOLLOWS:
Maybe the fancy test clamp in the production facility is part of the cell qualification process.
They measure the expansion and contraction during the first cycle.
Possibly the uniformity of the expansion and contraction also.
Just a guess, but I was wondering why they would go to the trouble of engineering a constant 12psi compression rig.
I know. Not happy. But we will see.Wow, that's weird. I never heard of any Li batteries being shipped at 100 % SoC.
What gap sizes are we talking here?
It's fine, I'm not concerned about the sides. Was just curious that if the whole point is to stop expansion, surely if there are significant areas that can expand, will that not have caused the damage already.Should be ok but given you're in a weird case photos would confirm if it's fine or not
Mine came with concave faces as well, at most 2 mm, I just checked with a straight edge. I consider it fine, more than that would be worrying.
Not a few times no. It is accumulative over a long period of time. Like months on an almost daily charge and discharge cycling.It's fine, I'm not concerned about the sides. Was just curious that if the whole point is to stop expansion, surely if there are significant areas that can expand, will that not have caused the damage already.
