Well, I bought mine from Dongguan Seplos Technology Co., Ltd.......waiting for arrival......now you just make me worry even more......Directly from Seplos on Alibaba (Shenzhen Seplos Technology Co., Ltd.) Using link from Off grid Garage website.
I dont wanna crap all over Seplos yet, they could still be legit EVE cells, but just older(april) than they said they would be.
Should new eve cells arrive prefect and not bulged?
EVE also sells raw genuine EV grade cells (passing all stringent testing) without any terminal to companies/bulk buyers.I _thought_ that grade A LF280K's had bigger terminals with two 6mm threads in them, like these...
They have now sent me a different test report. One that actually matches the cells I received.EVE also sells raw genuine EV grade cells (passing all stringent testing) without any terminal to companies/bulk buyers.
Not in my mind with all the other potential factors over the next 15 years.Should I have any concern that they are from April instead of Sept/Oct? Does the change the lifespan much?
Over 300Ah sounds rather good for LF280K's. Just use and enjoy themAlso the Capacity is less of the ones actually sent. All varying around 308-312ah vs original test report which was 315 (every one on the sheet was 315 or 316) . I would have thought grade A eve cells with have a tighter margin that between 308ah-316ah
Yes, it's normal for us. I have a theory that this is actually why they failed EV spec at the factory and end up on our market. They're not performance fails that get marked B, but they're physical fails for nonconformity. EV manufacturers probably are not happy if the cells don't fit exactly in their precision designed compression tray.Would it be normal to have a slight bulge for a new Eve cell? its hardly visible to the eye. Only whena straight edge goes on it
Doubt it, more likely difference in test assay. Likely to have been tested 3.65V to 2.5V unless you know otherwise. Different temperatures etc will all make a small difference.Is this normal degradation of a 10 month old cell with allegedly zero use?
