I have the same issue. I could buy 10KWh more of batteries and nullify my grid usage throughout 6 months of the year but for the other six months they will not be charging enough to make a dent in my grid usage.Even if my batteries were 4 times the size I would still occasionally have to run a generator in winter. It makes sense to me to leave the batteries as they are and spend $150/year on diesel.
It takes significant fuel/generator to create 40kwh/day as in 40kwh * 120days of winter = 4,800kwh / 5kwh per gallon = 960 gallons of fuel for just 1 winter.
Sounds like we had similar careers prior to civilian life.It is, but I don’t wanna. From living on top of a humvee to sea can villages to the over crowded ant colony called Seoul, I like my comforts.
And want a pool for exercising so I don’t kill my already jacked knees and back. And a hot tub for said back.
And my peace to deal with a life wasted serving the industrial military complex/deep state destabilizing and “rebuilding” (build back better? Lol) countries.
All doable off grid. Just takes some thought, money, redundancy, and multiple energy sources.
Different time. Today we are deprived if the smart phone loses signal.Is it realistic to just do without during difficult times? People did get by without electricity at all and not that long ago.
What do you consider a real winter?If you rely purely on electric for heating (even with a heat pump), doing so off-grid in places tat experience real winter is nearly impossible.
Is that some kind of Magic Dryer? ? Mine uses 5000 watts an hour. That's the only thing left on grid. I'll use a clothes line in a $HTFThis always make me wonder: why do you need 40kWh/day when trying to go off-grid? I use maybe 2kWh a day to keep the systems running, 5 to 6 with all the bells and whistles in winter. This is a normal house, with running water, flushing toilet, fridge, dishwasher, washer and dryer, etc.
Him? Think Artic Circle or nearly ?What do you consider a real winter?
That's what I was thinking too. ? My little 120 one uses less then 1500 watts (a little more considering inverter loss). Although takes like 2+ hours to dry a load. It's a washer ventless dryer combo machine. It "recycles" some of the heat by not having vent. It has a disadvantage of having to clean out the lint though as there is any lint screen, but you don't have to transfer your clothes from the washer to dryer!Is that some kind of Magic Dryer? ? Mine uses 5000 watts an hour. That's the only thing left on grid. I'll use a clothes line in a $HTF
I ask because I am all electric and use HP forHim? Think Artic Circle or nearly ?![]()
It's still almost mind boggling to me that we talk about running AC (heat pumps) off of solar PV like it's commonplace. Two thing have changed big time since I started dabbling with this stuff back in the 90's.At least one thing works in our favor.
The Summer excess power can be used to cool your house down
Well Upnorth according to his about page is at 63° North, FinlandI ask because I am all electric and use HP for
My heat.
Now last December I did have to break out the Generator for a bit because it was so rainy.
It got down to 4F degrees here.
5kW - wow...Is that some kind of Magic Dryer? ? Mine uses 5000 watts an hour. That's the only thing left on grid. I'll use a clothes line in a $HTF
Yeah that's what I'd think ... Or Coal Fired ?5kW - wow...
Probably not magic, but I'm guessing just a modern heat-pump dryer like the one below... manual says it draws 645W and dries 4Kg load in just over 1kWh, or 8Kg load with 1.8kWh - so assume it will take 2 to 3 hours.
WTH85222GB | Bosch Heat Pump Tumble Dryer | 8kg | ao.com
This WTH85222GB Bosch heat pump tumble dryer can hold 8kg of laundry and comes with AutoDry tech and SensitiveDrying system that leaves clothes wrinkle-free.ao.com
PropaneYeah that's what I'd think ... Or Coal Fired ?
That's only a 8 kg dryer though. Not tiny but might be too small for people that don't like to do laundry a lot. A larger capacity heat pump dryer would use more. That would be the perfect dryer for a medium RV.I wish mine used 645 watts. Mine is 4800 or 5000 watts. Hungry thing for sure.
But on the flip side it dries the crap out of clothes. My parents have the new fancy stackable ones and probably are the low wattage kind. Doesn't dry clothes worth a flip compared to my dinosaur![]()
I just put in a new Speed Queen set for my mom and went with with a gas dryer. Dries like a middle eastern wind storm. Was thinking about trying out an inverter type, but think I will go with propane until they ban em.I wish mine used 645 watts. Mine is 4800 or 5000 watts. Hungry thing for sure.
?How much clothes could a Wind Storm dry if a wind storm could dry clothes? ?I just put in a new Speed Queen set for my mom and went with with a gas dryer. Dries like a middle eastern wind storm. Was thinking about trying out an inverter type, but think I will go with propane until they ban em.
sonoff , controller by home assistantRight now when I see a "feast" coming, I'm frantically running around the house figuring out what extra things can be done. Dishes, laundry, etc. Trying to use all the potential possible while ensuring my batteries are full.
So how are you dumping power to the water heater?
Never knew such a thing existed. I have to research if there is any available in the US market. My ~28 year old 240vAC dryer is an energy hog but it does dry things (a typical load in under 40 minutes). I can not power it from my PV so it like my electric range ( almost never use it with all my countertop cookers/ovens) remain grid powered. Like others mentioned a clothes line can handle clothes dryer duties if needed.5kW - wow...
