My home base, including heat-pump hot water is significantly higher than 5-6kwh/day. The hot water alone is 150kwh/month (summer) to 200kwh/month (winter) which is (175kwh / 30days) is 5.8kwh/day. Running around 15-20kwh/day for a range of nice things.
The only regular heat/cool option I have is a high efficiency, forced-air, heat-pump for 2600sq ft, 1997 construction, pretty good insulation and I'm in a Zone 4 climate. Got estimates for wood burning stove but between city permits and house design (no good place for stove or exhaust) it was getting into $10-15K level. In a full disaster, the plan is to use kersone + propane for minimum temps (to keep house functional) and hang out in the trailer for full warmth
Here's the heat pump kwhs by month over the last couple of years..... As you say, heat is the main issue. With 14kwh PV array I've been as low as only 300kwh of useable power in December when I need at least 1500kwh to maintain a 70-74F modern level of living.
8 months are perfectly doable. It's Nov/Dec/Jan/Feb that are difficult and would need 250-300 panels (instead of 48) to get enough solar for December.
