robbob2112
Doing more research, mosty harmless
Unplugged the ups from the inverter and within 1 hour the battery has climbed to 14.4volts...i hope that is a good thing
Ok, I watched your video.
Wiring the 400w panel to the pwm then to the new battery is ok. The PWM you have is good for 20amps. The 400w panel has 22amps available. So that is good.
DO NOT CONNECT ANY MORE PANELS.
You need to go into the menu of the PWM And set the battery type to AGM or B02. This will use the proper charge and float voltages.
Once that is done disconnect all loads and let the battery charge from the sun for a day to get it fully charged.
After a day plug just the laptop and monitor into your inverter. The rest of the things you have plugged in draw to much current from the battery. The fridge especially.
You may have already done it, but please post still pictures of the inverterer. Looking to see if the rated watts is listed and seems reasonable. Make sure they are in focus. And the link where you got it. And with just the computer and monitor connected see if the inverter is hot to touch.
Only plug the UPS into the wall at this point, not the inverter.
Also, take a picture of your connections to the new battery. In focus and post.
