robbob2112
Doing more research, mosty harmless
The PWM can only do its job if the correct battery type is programed. Or the correct voltage for 100%. It should have a battery type setting and one that is programable. You want to set it to AGM or 13.0v for 100% SOC
Test all other panels for voltage. I imagine they will all be 18v
Test all small panels for amps. Hold off on the largest panels until you can do them straight up away from sun and gradually tilt into sun. If the largest panel is really 400watts it pushes 21 amps which would blow the fuse on your meter. By doing straight up and tilting to gradually get sun you can stop when you hit 8 amps or so and know if you are not flat on that it may be what it says.
In the end before proceeding we need to know voltage and current for each of your panels.
If you will refrain from getting ahead of us we will do everything possible to prevent any more kaput problems.
