callmeburton
- Mar 4, 2022
- 258
It does BUT not for LFP batteries ... if you set the unit to LFP then it requires COMs from an external BMSInteresting, it doesn't have standalone charging control.
I'm not really sure I'd want my BMS to control charging, I look at a BMS as protection.
In the SMA SI CAN protocol 0x351 is required and sets battery charge voltage, dc charge current limit, dc discharge current limit, and discharge voltage ... if you don't pass these it wont work with LFP
There are a couple other fields but they don't relate around charging / discharging.
