live4soccer7
- Jun 15, 2020
- 670
Where are you getting panels that cost $.20/watt? The best I've been quoted is a little under $0.50/watt on the panels. The fronius inverters are roughly $0.25/W and I haven't priced out the ground mount, but let's say the one from blue sun is $4k with freight for 25kw then that would be about $0.16/W.Height of things like weeds or other shade would be the main concern.
My original arrays used 18' Unirac rails, which I think were custom cut to fit 8, 120W panels. Standard sizes seem to include 17' and 20'.
They come within about 18" or 2' of the ground.
What is your panel electrical (series/parallel) configuration?
By making two physical arrays of different orientations (e.g. 10:00 AM and 4:00 PM sun would be 90 degrees apart), parallel strings peak at different times, delivering more watt hours for a given peak wattage. Total available watt-hours/day would be less than with ideal orientation, but utilization of inverter could be about 40% higher because peak is 70% as high.
Depending on ratings of MPPT inputs, you may be able to have each string on its own input. Multiple strings of different orientation wired in parallel will capture about 2% less due to not quite operating at Vmp (unless shadows fall on a string, making loss greater.)
With mounts costing $0.15/watt, panels costing $0.20/watt, and inverters $0.15/watt (approximate), this should deliver more energy per dollar. Also, more energy within maximum power allowed to backfeed, or maximum charge rate of a battery backup system. Battery backup would be kept fully charged later into the evening, reducing capacity used at night.
On the surface, without digging into it deeply, I was thinking of doing 16-17 panels in series and then putting them all on their own MPPT inputs. Each series run (5) would get a run back to the inverters. There would be two series per inverter (15k fronius primo). I'm not set in stone on the fronius inverter at this point, but kind of what I've been going with. For the system I'm doing, it made more sense to go with a larger output capable inverter with a higher DC voltage rating.
Right now, the field I'm putting the panels in is in full sun (745AM). It will then start to get shaded around 7-8PM. There are no trees or obstacles in the way except the very beginning and the very end of the day.
