Ucatchmydrift
- Jul 2, 2022
- 195
Hi, love this forum, it has/you guys have helped me alot over the last 6 months when i started thinking about building my own diy solar setup here in cloudy sunless england.
Nearly finished it all now (although, i think its gunna be one of those projects that i keep adding to or modifying), so i thought id share what i have done as tbh im really pleased with myself ? seeing as only 6 months ago i knew nothing about solar.
To many of you this will look like a small project, but, i live on my own in a 2 bedroom bungalow and dont have alot of space for solar panels, and would be tricky to put them on the roof without needing a bunch of help.
Energy prices have sky rocketed here in the uk (although the government has helped a bit by paying everyone £400 towards elec and gas - which we will obviously have to pay back with interest in the future!), so has been the perfect time to do this.
I found 12 x 240w jinko panels second had from a solar farm in germany from a local seller for £700, put them on my workshop roof, and the shed roof that i built last year:
As you can see, a lovely day here in east england! Blowing a gale and raining!
The panels are in series and two parallel. And get a bit of shading first thing in the morning.
Inside the metal shed is where i keep the inverter and battery storage. Its an all in one epever 3kw:
Inside the workshop?
Pv fuses, isolator and breaker?
200amp dc breaker and 300amp isolator ?
Please ignore the exposed wiring above, im in the middle of experimenting with using a relay, controlled by a junctek shunt to switch on grid supply when the battery gets low, as having permanent grid supply to the inverter means it draws a continuous 10w from the grid! - cant have that! Atm grid supply is controlled via a wifi smart plug shown above, which switches on a contactor which allows the inverter to then charge the batteries at cheap rate times only, which i shedule via the smartplug app. The shunt grid control will be for if the smartplug fails. All seems to work (well - it did until i fried the relay side of the shunt control box!) - got another on the way for my second battery bank anyway so will use that one instead.
Now getting the busbars ready to attach the current battery bank, and the new one that im now top balancing in parallel ?
First battery bank made from eve grade a 280ah cells from fogstar uk, compressed, top balanced etc, using a 200amp jk bms at 8s (24v), and the junctek smart shunt.
Below the battery is a heating mat controlled by a thermostat shown in the previous picture, and has been needed recently - hence the blanket around the battery - this will be changed soon to some pir insulation stuff.
Second battery bank getting ready ?
